4th gen lower control arms
I need to replace my passenger side lower control arm on my '94 (car in sig). I found a set of lower control arms on ebay off a '00 3.8 litre car. Does anyone know if there were differences in the control arms between LT-1 Cars and the LS-1 style cars (or V-6s for that matter?). TIA.
Re: 4th gen lower control arms
If you want to upgrade those control arms, get these bushings pressed in.
They are a direct replacement for the star cut OEM bushings.
1LE Rear Lower Control Arm Bushings (GM p/n 10164152) (4 required, bushing only) $8.40
* These are solid rubber and not cutaway for soft ride like the stock Z28 bushings. I would expect them to be a pain to install.
Z28
Z28
