4th Gen Rear Lower Control Arms and Panhard Rod?
Old 05-05-2006, 11:33 AM
  #16
Dave K's Avatar
Re: 4th Gen Rear Lower Control Arms and Panhard Rod?
I like the rod/rod designs myself. Sure they're a bit noisier but It's not bad enough to be annoying for me (and while the car isn't a daily driver, I've been driving it a lot lately). I've got the front all rod end, back poly right now... back is going to rod end next year.
Dave K is offline
Old 05-05-2006, 03:07 PM
  #17
He's thinking of the earlier GM cars.... the LCA's had the mounts for the sway bar. My 1966 GTO was set up that way.....
But a 4th gen has separate mounts for the sway bar.
Rod ends, and nothing else......
Injuneer is offline
Old 05-05-2006, 04:27 PM
  #18
350350's Avatar
Originally Posted by Xride
The Sway bar does not mount or come into contact with the LCA, so no worries there
While your odering thing you may want to consider LCA relocation brakets, I know with the SS SLP suspension its right in the middle of needing them and not, but wouldnt hurt.
Yeah, I went out and looked at the SS and it's got different mounts than my Malibu... My '83 Malibu still has the sway bar mounted on the LCA's... Anyway...
I saw the LCA relocation brackets, but I'm not sure I follow what they do... Do they just give the LCA more leverage against the twist of the axle? What is different between the SS and Z28 suspensions that makes a difference? I am pretty sure my '97 SS sits higher than my '95 Z28 did, just a little...
350350 is offline
Old 05-05-2006, 08:18 PM
  #19
Bud M's Avatar
Relocation brackets change the angle of the LCAs between the chassis and the axle. They lower the axle end of the LCA which has the effect of pushing the axle downward under acceleration to increase traction. On a lowered car the chassis mount gets lowered which changes the angle of the LCA and the relocation brackets compensate for that change.
Bud M is offline
Old 05-05-2006, 08:46 PM
  #20
LT1Formulation's Avatar
Would relocation brackets help on a car that isn't lowered any? To get a little more bite, that is.
LT1Formulation is offline
Old 05-05-2006, 08:57 PM
  #21
ABA383's Avatar
Some have had great results with them. I saw none with my non-lowered set up when I had them on my 10 bolt. I currently do not use them on my Strange 12 bolt and I hook very well...
--Alan
ABA383 is offline
Old 05-06-2006, 08:31 AM
  #22
350350's Avatar
--Alan
So when you use the brackets with adjustable LCAs, do you leave the LCAs the stock length, or do you extend them to meet the new bracket location?
350350 is offline
Old 05-06-2006, 09:00 AM
  #23
Bud M's Avatar
Mine are stock length (non adjustable), the fit is fine.
Bud M is offline
thenewkid
11-27-2014 09:41 AM
MIGHTYMOUSE
08-29-2002 09:18 AM
PaulN64
08-08-2002 05:39 AM
PaulN64
08-07-2002 06:17 PM
DubbyZ28Camaro
08-04-2002 12:53 PM
Quick Reply: 4th Gen Rear Lower Control Arms and Panhard Rod?
