From 82 to 02, rear swaybars are the same fit?
Looking at a few sites that allow you to shop by gen. the front is gen specific but the rear can be interchangeable?
Trying to find some options or choices with hollow sway bars at a reasonable price and this may be it.
Now does anyone know if SLP's 21mm rear sway bar is hollow?
Re: From 82 to 02, rear swaybars are the same fit?
Front bar is bent different to clear the later engines 93-2002.
Rear bars are supposed to be the same.
The SLP & GM 21mm rear bar is solid. Factory 17mm & 19mm rear bars are solid also.
GM 30mm and 32mm front bars are hollow. Strano has a 35mm hollow front bar, Hotchkiss makes a 36.5mm hollow front bar.
Sam Strano makes a 22mm hollow rear bar. If you want to drop some weight he could hook you up. Only hollow rear bar I am aware of.
Z28
Z28
10-31-2016 11:09 AM
12-04-2014 11:56 AM
Wilson
07-21-2002 05:08 PM
