94 Suspension
94 Suspension
I have a 94 Camaro V6. The thing rides really really rough. When you go down the road, every crack I hit it makes a thug noise. What can i do to fix this problem? Im getting new tires on it hoping that will help. Someone else suggested stiffer shock or lowering springs. Can anyone give me any recommendations?
Re: 94 Suspension
Stiffer shocks and lowering springs? No.
You need *better* shocks. Parts of their valving are stiffer, parts are softer. The stock shocks just have really bad valving, and they are responsible for most of your stiff legged ride.
Bilstein HD's @ $349 are a good option for a V-6, but we do run a different HD rear shock that what's in the catalog. Recently Bilstein screwed up the rear HD's for this car, so we started using another HD for another F-body.
Re: 94 Suspension
Sam is correct. Lowering your car and going with a stiffer shock will generally make your ride even more of a rough ride.
Sounds like you need a new set of shocks to me. Tire's shouldn't make any difference unless you are changing sizes, or have been running around on flat ones.
