94 Z28 Suspension
94 Z28 Suspension
i got a 94 Z28 Lt1 last month just got in some Ksport 1.8" drop springs for it but i wanted to ask others here what the best Suspension u can buy for that car? Every time get on it all it dose is spin but i saw someone had the same car up town when he got on his he didnt spin a tire and came outta the hoe good but he wouldnt tell me which Suspension he got because he dont want me have a better car then his.So any one on here know some good suspension i can order for my car? and thanks for yall time.
In order of importance:
-sticky tires, properly inflated
-Tubular or boxed rear lower control arms (LCA) with poly, spherical, or poly/spherical bushings - depending on the ultimate use of the car.
-rear LCA relocation brackets (might even be #1 with a car that has been lowered 1.8")
-tubular panhard rod, with firmer bushings, as on the LCA's (adjustable is important for a lowered car, to recenter the rear of the body over the axle)
-healthy shocks, correctly matched to the springs.
Subframe connectors will always help... but not as critical to rear wheel traction as the items listed above.
Click on "mods list" in my signature, and scroll down to the "Suspension" section.
-Adjustable torqu arm for higher HP applications
F'n1996Z28SS
08-23-2023 11:19 PM
10-31-2016 11:09 AM
Hurin
12-13-2014 07:38 PM
1LEThumper
07-14-2003 12:45 PM
