95 c5 upgrade parts list?
i got the calipers now what else do i need?caliper adapters are avalible from gmpp but they are like $325! thats just crazy ,if i have to buy them then i wish id just gone with willwood.any help?
there's some knockoff's on ebay for 80, or one of the more prominant camaro parts sites has a setup for cheap too.
you'll need either loaded calipers (the cheap route since they have the abutment brackets, pads, and banjo bolts/washers included), and brake lines for the vette (file off the directional tabs on the brake lines, you'll know what i'm talking about when you put them on), and that's it
or, buy calipers, pads, abutment brackets, bolts, shims for the pads, banjo bolts and washers, and all minor parts seperately.
i found that the loaded calipers are much cheaper than buying parts seperately, and they come with the zo6 pads....nice for about 80 bucks each
The "SEARCH" button on this board is your friend.But since a im such a nice guy.I ve search my original post
It took me less than 2mins to find it:
http://web.camaross.com/forums/showthread.php?t=464871
Look at the reply number 5 for the parts needed and the number 6 for the instructions.
You can buy some UMI brackets wich are also very good .
I got my parts from Kore3. Excellent product with great customer service. You will need:
-Calipers
-Abutment brackets
-conversion brackets
-rotors
-pads
-the hardware for the conversion bracket
-hoses(I got kore3 braided hoses that don't require any filing)
-brake fluid
-banjo bolt
-copper washers
...i think thats all
I used the metabo(sp?) to cut the spindle instead of a sawzall.
-Calipers
-Abutment brackets
-rotors
-pads
-brake fluid
-banjo bolt
-copper washers
11secgen:
Try this page link ... UMI sells the adapter plates for $240. Abutment brackets too. Or there is Jason at Sam Taylor Chevy.
http://www.umiperformance.com/produc...category_id=30
