96 Z28 - (6) rubber brake lines ??
I just purchased a '96 Z28 for a track car at Watking Glen. I want to swap out the rubber brake lines for SS but ..........
...... there are (6) rubber hoses and all the SS kits I found show either (4) or (5) SS lines, but no (6) line kit.
Any suggestions as to what I could buy?
There are two (2) steel lines coming to the rearend from the front of the car (not just one). Each of these steel lines ends before the rearend and then connect with rubber hoses to two steel lines on the rear itself. The two lines independently feed the RR and LR brake calipers all the way from the front.
You have a car with traction which uses 6 hoses. This is what you need below.
http://www.hotpart.com/shop/index.ph...ct_detail&p=39
Yes --- Thank You!!
F'n1996Z28SS
08-23-2023 11:19 PM
