Abs Inop
Abs Inop
just got done putting the mods in that are in my sig.......yesterday i didn't see it on, but tonight it came on probably like 10 seconds after I put it in drive......doesn't come on right when I start the car, and if I let it idle for about 1 minute or so it never comes on.......but as soon as I put it in drive, a few seconds later it pops on and stays on. Nothing seems out of the ordinary, as far as driving goes....I don't feel any problems. WTH? Thanks in advance!
Re: Abs Inop
You could try pulling each sensor harness connector and cleaning the connection, checking for frayed wires. Try blowing the dirt out of the sensors with high pressure air. Pull the rear sensor and check for metal particles built up on it. Look for ways excessive moisture can get into the sensor.
But the best way is to do what Dave suggested and have the EBCM module scanned for codes. That will give you a very specific answer.
Re: Abs Inop
Re: Abs Inop
Originally Posted by GT KILLER
OK, so it really should be nothing major, right? Like nothing too high-cost to fix?
You can reference off this thread: http://web.camaross.com/forums/showthread.php?t=454703
Re: Abs Inop
Well, updated news to report: drove the car to work this morning......didn't see anything. Just got home from work.......didn't see anything the whole ride home.
Puzzling, indeed. Although I do remember last summer that ABS light came on once, but never was to reappear again until last night.
