ABS Inop after longtube install
I started my 97 ta up after installing longtubes and "ABS Inop" comes up on the dash as soon as I start it. I'm clueless as to why.
Re: ABS Inop after longtube install
Originally Posted by matLT1
Did you by chance disconnect the speed sensors up front during the install and forget to reconnect them? I'd take a look at those.
its pretty common for a wheel sensor to set off the abs inop light. i have the same problem with my light after pulling the motor and redoing it. not sure whats up, but i have other issues to worry about right now. i'll let you know when i get to it.
Yea the header on the passenger side is right next to the passenger side ABS sensor wire. Follow that ABS sensor's wire and you may notice a connector that is burnt to a crisp that just happens to be right next to a header. That happened to me and a friend.
Originally Posted by 2000GTP
This is a pretty common mishap, I believe I secured that wire harness away from the header with some cable ties in order to avoid cooking it.
I noticed the abs inop light a few minutes after startup because I wasn't paying attention to the dash at first. I think it probably went on immediately at start up.
jj_burchiel
03-21-2015 12:51 AM
dluna333
15
03-13-2015 12:30 PM
