abs inop and brake light
i got my rear gears changed on saturday . i went from the stock 2.73 to 3.42. anyway when the mechanic was done with the car i got in it and the first thing i noticed that both the abs inop and the brake lights were on. i aksed the mechanic about this and he told me that the problem was that since there are new gears there now the computer cannot properly read the sensor so it is causing the lights to turn on. is this possible? again i had no lights on b4 the install. can it possibly be a loose wire or something? thanks in advance for your help
He may not have plugged in the connector for the speed sensor on the rear end. No way to get more detailed without knowing some basic info about the car (why, oh, why do people never post this?).
What he told you is bunk.
![Frown](https://www.camaroz28.com/forums/images/smilies/frown.gif)
I don't remember having an ABS light issue when I went from 3.42's to 4.10's years ago. Of course your speedomter will be off until you reprogram the PCM. Like Shoebox stated, double check that everything is plugged back in (ABS sensor in the top of the differential).
jj_burchiel
03-21-2015 12:51 AM
dluna333
15
03-13-2015 12:30 PM
squarehead
01-15-2015 07:02 PM
