ABS INOP Diagnosis
ABS INOP Diagnosis
Hello I have a 95 Z28 6speed. I am tring to get the trouble code but it keeps saying communication error. I am trying to access the codes throught the ABS program in my Snap-On scanner, Am I supposed to plug it in at the same location I do as when the Service engine soon light comes on? To read the engine codes I am using the trick where you run the two wires from the OBDl adapter to the connector and that works fine.
please help, will
please help, will
Re: ABS INOP Diagnosis
What problem are you trying to diagnose? Did the ABS inop light come on? Is it on consistantly or intermitently? Are you having braking problems?
I don't have any info on using a scanner to get ABS trouble codes, but if you describe the problem a little more, I might be able to help.
Steve
Steve
