ABS Inop only when moving..
Re: ABS Inop only when moving..
Could be dirt on the sensor, corrosion on the harness connector, loose harness connector, metal particle buildup on the sensor in the rear axle housing. Worth checking them all out. Or find a shop with a Tech-2 and have the EBCM scanned for codes. That will tell you exactly what and where the problem is.
