ABS inop problem
ABS inop problem
I have been having a problem with the brake system on my 94 camaro. It takes a lot of power to brake the car and sometimes with the pedal all the way to the floor it keeps rolling. The as inop light has also been on when i start the car and when the car is in drive. Any help would be great.
I just replaced the brake pads on each side and checked the calipers and they were fine. I havent bled the lines yet. A couple of places i called said that it may be the sensors in the hubs. Not sure where to turn next
If no traction control, the sensor is screwed in to the top of the hogs-head....3channel ABS.
If you have traction control, you have a sensor at each brake backing plate....4channel ABS.
hope that helps,
Doug
hope that helps,
Doug
As for the brakes not giving you good stopping power, as said before thoroughly bleed the brakes starting with the ABS module and then working the rear pass side, rear drivers, front pass, and finally front driver.
As for the ABS inop light. It could be the sensors in the hubs, the rear sensors, of the most common cause...
Check the center mounted 3rd brake light... If the bulb burns out, it will trigger the ABS inop light. There are 2 bulbs in the center mounted 3rd brake light.
Thanks for the help the ABS INOP light is off but i still have a braking problem. Im going to have the brakes bled by a shop since i heard that you have to have a program tool for the job.
jj_burchiel
03-21-2015 12:51 AM
dluna333
15
03-13-2015 12:30 PM
