abs light on
Re: abs light on
Has nothing to do with the brakes and rotors. Anti lock braking system appears to not be working. If you want it fixed, I would take to a shop and have them look at it for you. There could be some fuse or relay that might need replaced or something bigger is wrong.
Re: abs light on
Abs is working great it has to be a sensor or fuse,or relay
Re: abs light on
Doesn't the dash light say "ABS INOP"? Unless you have a short in the lamp circuit itself, the light is telling you there is a fault that has caused the electronic braking control module (EBCM) to turn off the ABS system.
jj_burchiel
03-21-2015 12:51 AM
dluna333
15
03-13-2015 12:30 PM
squarehead
01-15-2015 07:02 PM
