ABS malfunctioning: modulating under normal braking conditions
Old 06-02-2006 | 08:58 AM
boosted-lt1's Avatar
I have this intermittent problem with my 1995 Camaro. When approaching a complete stop, the low traction light comes on and the pedal begins modulating as if the tires are locking up. This is under normal braking conditions where ABS should not be proportioning.
Has anyone encountered this or know what could be wrong? Maybe a faulty wheel speed sensor? What can I check?
Thanks,
-Scott.
Old 06-02-2006 | 09:06 AM
Lunch Box's Avatar
Re: ABS malfunctioning: modulating under normal braking conditions
I don't know how you'd check but it sounds like a faulty wheel speed sensor to me . . . I had similar problems with my '98 Chevy Ext Cab and had to replace two wheel speed sensors
problem solved
Old 06-02-2006 | 02:48 PM
I had that identical problem when the rear axle sensor started to have problems with clearance to the reluctor ring. You might want to pull the sensor and make sure there are no metal particles building up on it.
If it was a totally screwed up wheel sensor, you would get the "ABS INOP" light on the dash.
Old 06-02-2006 | 04:20 PM
Lunch Box's Avatar
Tried to clean mine before replacing them, didn't solve the problem . . . should have mentioned that first
Old 06-02-2006 | 05:54 PM
Thanks guys,
I should have mentioned too, that the ABS INOP light does come on after the low traction light.
When it happens, it is in this order: low trac light and pedal modulates as vehicle stops, when stopped ABS INOP. The ABS light may go off and the process repeats.
This just started and doesn't happen all the time.
I replaced the rear end gears about 1500 miles ago but I will check the sensor.
Thanks again,
-Scott.
Old 07-08-2006 | 03:50 PM
Koby's Avatar
My car does this same thing, only my abs light stays on constantly. Once the Abs light comes on my brakes function like normal. I tried to find a wheel speed sensor on the autozone website, but no luck....what is it called and does anybody know the price of one of these things?
Old 07-08-2006 | 06:37 PM
OBE1 95Z28's Avatar
The ABS light can come on for many reasons; it will be very expensive to just start buying parts to fix you problem. You can have the code read for the ABS issue to narrow down your issue.
Old 07-08-2006 | 08:16 PM
rngilliland's Avatar
The front sensors are part of the hub. It is a sealed part and you can't replace just the sensor. The rear one is on top of the center section of the rear if you have abs only and at the ends of each axle if you have traction control.
I agree you should have the codes read. You will probably have to go to a dealer to have it done.
jj_burchiel
03-21-2015 12:51 AM
dluna333
15
03-13-2015 12:30 PM
dluna333
Parts Wanted
03-06-2015 07:11 AM
squarehead
01-15-2015 07:02 PM
HCz28
01-11-2015 11:21 AM
Quick Reply: ABS malfunctioning: modulating under normal braking conditions
