abs module
Re: abs module
Not 100% sure but I think the difference is whether it has traction control or not. Looked through the shop manual and the parts manual and it seems the only difference is the gear kit that the motor pack drives to operate the abs valve module, the valve module shows as one part number 18029923 for all 93-97 F-body, motor pack is 18024454 for all 93-97 F-body, there are different gear packs for traction control (NW9). No engine references anywhere in the parts manual with respect to ABS module. Hope this helps.
Re: abs module
The factory manual does not indicate any difference based on engine. The difference would be the 3-channel motor pack for the ABS-only cars and the 4-channel motor pack for the ABS+TCS cars.
