ABS Removal W/proportion valve
My ABS has problems Its thrown 10 DTC codes out at me my best diagnosis is that the ABS motor is shot. Anyway I think I am taking it off, my question is how much do you proportion your back brakes from your front with a propotioning valve. If anyone knows Thanks
O Yeah I'm pist because I just got my Moser 12bolt and paid to get the ABS ring on it.
Re: ABS Removal W/proportion valve
I'm currently not running a proportioning valve with my setup and the braking is awsome. There is no set amount to proportion your back brakes. I depends on driving style, any brake mods you've done, tire size etc. I would simply install an adjustable proportioning valve on the rear and mess with the adjustment until you like the feel. After which, give the rear a little more pressure. With no ABS, you want the rear to lock first during heavy braking.
Re'
Re'
10-31-2016 11:09 AM
jj_burchiel
03-21-2015 12:51 AM
squarehead
01-15-2015 07:02 PM
GA93FORMULA
07-24-2002 11:38 PM
