abs wheel sensor
abs wheel sensor
how do i clean a wheel sensor? my abs inop light came on and when i had it checked it was the wheel sensor and i was told that i can clean them and it may start working again.
take the sensor out and wipe it off. try using compressed air to blow any debris form the reluctor wheel area. usually dirt will not interfere with abs sensor operation. unless its exessive like if your brakes went meatal to metal and the sensor was coverd in meatal shavings. more than likely you will have to replace the sensor.
Only the rear sonsors can be removed. The front sensors are mounted in the front hub assemblies and are not able to be serviced.
Generally, cleaning won't accomplish a thing as they are magnetic. Your gonna have to replace it unless the plug is just loose or something.
Re'
Re'
Re'
Re'
jj_burchiel
03-21-2015 12:51 AM
BandDirector Blk98ZM6
02-20-2015 07:42 AM
squarehead
01-15-2015 07:02 PM
