adjustable Panhard Bar help asap???
i need a adjustable Panhard Bar wat is the bets bar out there in a good price???
also BMR adjustable Panhard Bar good???
Panhard Rod, Chrome Moly, On-car Adjustable, Polyurethane Bushings
Part#: MPHR002
Manufacturer: BMR Suspension
Part#: MPHR002
Re: adjustable Panhard Bar help asap???
There's really not a whole lot of "tech" in a panhard bar. The biggest decisions are what kind of "ends" you want on it - poly or spherical rod ends - and whether you want single adjustable (pull one end off the bolt to adjust it) or a double adjustable (adjust without removing an end). The one you linked is poly and double adjustable.
Chrome moly only makes sense if you are looking for the last few ounces in weight savings. Not worth $55 extra over mild steel.
