Adjusting Koni rear DAs without knob
Re: Adjusting Koni rear DAs without ****
Originally Posted by TA-Body
I just got the koni rear das on my car, but the guy i bought them from didn't give me a **** for the rebound on top, all i get is a point like this I tried puttign a wrench on it and turning it, but it jsut turned and turned freely. ANy suggestions?
http://www.koni-na.com/apparel.cfm?l...ubmit=Continue
There are no clicks on the rebound adjustment. That is an advantage to buying the ****. You count the bumps on the **** to know where you are. Eight bumps on the ****. Total of around 2-2 1/2 turns possible.
You only need one ****. Set the shocks to full soft and install them with the little flat piece turned the same way on both sides to make adjustment easier side to side.
Rears are easy to install, fronts will be more work, but they don't need a ****. You should get a 2.5mm allen wrench to adjust them with. Koni website tells you how.
Z28
FYI,
Like I said earlier you only need one ****. You don't leave them on the shocks. Just swap from shock to shock as you need to adjust then put it in the glove box.
Z28
Z28
