adjusting pinion angle?
Re: adjusting pinion angle?
I ve tried the method that consist to take the measure diffrence between the
ds and the ta.It was good but not perfect.
You your engine is always(99%) of the time leaning down.So you need to take this in consideration.Since you transmission his connected straight to the engine its also leaning down.
So here is the link:
http://www.streetissuecustoms.com/pinionangle.html
