air bags?
air bags?
Air bags are on Thunder's site for $60. They're suppost to correct the "twisting" action the chassis experiences during launch that causes the left front and right rear tires to lose traction(left front leaves the ground-sometimes). Is this a wise buy to help traction or am I just being a dumb ***?
Putting an air bag in the right rear spring will help control the twist on launch that lifts the left front wheel and causes the right rear corner to squat. You could accomplish the same thing by using a "race style" rear sway bar, like the ones from Wolfe or Spohn.
You can't put an airbag in the front spring..... there's a shock inside. And why would you want an airbag to lift the left front, when its the left front you are trying to keep down?
Squating does not necessarily increase traction. Getting the rear of the body to lift on launch can drive the tires into the ground.
Alone that line of thinking why would you want an airbag in the rear when you are trying to keep the rear down (on the ground to get traction)??
I thought the air bag was to basically "pre-load" the suspension. Don't airbags lift the body in relation to the wheels, putting a downwards force on the wheels?
You are preventing the body from dropping on the passenger rear corner. As the right rear drops, the left front comes up. Its just like putting a stronger rear spring on the passenger side in the rear. It keeps the rear of the car level. The torque reaction to the pinion shaft load lifts the drivers side of the car and drops the passenger side. As this happens, the car gets really squirrely, pulling to one side on launch. Keep it level and it will launch straight.
Here's a perfect launch for a heavy, high HP car (1,350HP)..... car perfectly level, rear of body lifting over the tires, and front wheels just barely off the track surface.... no traction problems whatsoever.
Z28amustangklr
Middle Atlantic
03-28-2015 03:08 PM
squarehead
01-15-2015 07:02 PM
