all four of my wheels *drag*...
Ive noticed some horrible noises my car makes when driving. At higher speeds (60-70 especially) the front makes a rythmic hum, ESPECIALLY if i apply any pressure to the left. And any time I get going more then say, 20 or so, I hear from the rear a clicking or scraping noise. If I jack up the car and spin the tires by hand, all four make a metallic dragging noise. They should be quiet, right? I took it to the mechanic I usually go to and he said he could barely hear it but I know its there. the noise coming from the front is very noticeable at higher speeds. This thing is driving me nuts!
Re: all four of my wheels *drag*...
you're having all sorts of problems man, the thread about low mpg and now this! =(
:edit: pull off the worst wheel and check the backside of the disc to see if theres anything rubbing somehow there. seems like a no-brainer to check the discs but if you havent looked at hte backside maybe see if the culprit is there
30th Anniv Z28
08-01-2015 10:39 AM
jasonduaine
06-04-2015 09:29 AM
