Another drag setup question
Old 10-16-2007, 06:54 PM
  #16
97s10ondubs's Avatar
Originally Posted by danhr
define "dead hook" too..... as in you want to punch it from a dead idle/stop and want it to hook? your ideal launch from a m6 is just a little bit of wheel spin.
first thing i would do is ditch the lca's and rear shocks. the stock lca's are very flimsy and shocks is the key element in suspension.
I honestly don't think a tubular k member shouldn't be on your shopping list at the moment. that money can be spent elsewhere and get better results. if you want that weight reduction, take out the front bumper supports... it's free and saves just as much weight. just hope you dont get in a front end collision
Yea I mean be have a decent launch on the street like not blow the tires off if i launch it from 2500. It has tubular lcas right now, eh i guess you're right, i dont need to spend $500 to save 25lbs. I'll just spend that to get all new shocks/springs and maybe an airbag, TA, and lca relocations.
97s10ondubs is offline
Old 10-16-2007, 07:03 PM
  #17
danhr's Avatar
i honestly think you would benefit more from a drag bar than an air bag. from what I'm told/gathered an air bag is just a "band-aid" instead of a drag bar. The drag bar allows you to preload both sides of the rear suspension, as well as minimize body flex (which judging from your pic, you are suffering from). That and a drag bar you just dial in once and your set, an air bag you are constantly adjusting.
Post some 60' times after you do some suspension mods. I'd like to see how well the car improves.
danhr is offline
Old 10-17-2007, 08:36 AM
  #18
Z-RATED94's Avatar
I agree a drag bar would be best, but no harm in starting off with the air-bag to see if it helps. It's fairly cheap compared to a drag bar. Just putting the Spohn adj. TA on would greatly change how the car launches. You will have less squat and more force planting the tires.
Z-RATED94 is offline
Old 10-18-2007, 07:03 AM
  #19
I'd rather go with the drag bar, dont want to get something then change it. This car sees the track a lot so that's what i'm going to do.
Old 10-18-2007, 11:17 AM
  #20
Z-RATED94's Avatar
Any idea on how the drag bar effects handling on the street?
Old 10-18-2007, 11:23 AM
  #21
guess i'm gonna find out
Old 10-18-2007, 04:12 PM
  #22
danhr's Avatar
drag bar isn't that bad. you get a little bit more over steer (if you don't carve corners, you probably won't notice) and the qa1 joints are a little bit noisey sometimes, but you will have that will all qa1 joints (i.e. lcas, phb, torque arm, etc).
I daily drive mine with a drag bar and no front sway bar.
danhr is offline
Old 10-19-2007, 08:32 AM
  #23
Shon Herron's Avatar
Let me know how I can help you.
Shon Herron is offline
Old 10-19-2007, 09:49 AM
  #24
how about a discount on a large order?
Old 10-19-2007, 09:57 AM
  #25
NO PROBLEM!!
Old 10-19-2007, 01:41 PM
  #26
danhr's Avatar
free parts?
danhr is offline
Old 10-19-2007, 03:00 PM
  #27
free parts?
Free...my wife doesnt get to stay at the house for free
Old 10-19-2007, 03:38 PM
  #28
danhr's Avatar
I'll put out, does your wife still do that?
danhr is offline
Old 10-19-2007, 03:43 PM
  #29
We have a date Saturday, I'll know then
Old 10-19-2007, 05:19 PM
  #30
NO PROBLEM!!
pm...
10-31-2016 11:09 AM
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
Moshbmx1
01-20-2015 03:27 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
01-14-2015 02:18 AM
Quick Reply: Another drag setup question
