Anti Lock Brakes on Third Gen Camaro
I want to dramatically improve braking distance. Can I swap out a 4th gens ABS system into a 3rd gen IROC-Z? I figure it would be alot cheaper if it's a used setup as opposed to new. Wha do you think?
Re: Anti Lock Brakes on Third Gen Camaro
abs does very little to shorten your stopping distance, what it does is allow you to steer while panic breaking
u wanna stop faster, get some real wide, sticky tires, real big brakes all around, and lighten the car as much as possible
A lot of guys are doing the LS1 front swap. Check out thirdgen.org - I'm sure there are posts about the swap. Our rears (if you have disks) are not too bad with some good pads. You can also do a LS1 rear swap, if you have drums.
If you have the $$$ though, Baer makes some sweet setups that bolt in.
i have an 87 iroc and i'm in the process of doing an ls1 brake upgrade
check out bigbrakeupgrade.com
its alot cheaper then the other kits and its alot better than stock
i didnt order the kit because i can do most of the work myself, and i can get parts cheaper, so i bought only what i need, email him, i'm sure he can work somthing out if you send him your spindles (thats if u can afford to have the car sit for a while)
ChrisFrez
12-21-2014 09:47 PM
ChrisFrez
12-07-2014 06:01 PM
ChrisFrez
12-07-2014 11:32 AM
