any ever made their own suspension???
just easy things like
rear lower control arms, adjustable pan hard rods, torque arm, subframe connectors or a strut tower brace...
has anyone ever made their own??? i am contemplating doing this, but im not to sure if they are made to special diameters or if they are just strong steel tubular peices........
Thanks guys
Scott
Thanks guys
Scott
Re: any ever made their own suspension???
I did the LCA's & PHR from this site... they work awesome.
http://www.jonaadland.com/Z28/Mods/L...minumLCAs.html
would you mind if i e-mailed you or called you????? i really wanna make mine too just because i think it would be a good learning experience....plus cost less for me to make.
did you make yours out of Aluminum like the site??? or did you make yours out of chromoly or rolled steel or just plain steel????
and i would like to see pics of your to see how yours turned out....................thanks man
Scott
Scott
Mine look just like the ones on the site. I bought the same AL from the same places, but I got my QA1 rod ends off Ebay instead; it was cheaper. I'm also running the Seals-it rod-end seals to help the ends survive a little longer.
It's not really building your own, it's more just buying pieces, and assembling them yourself.
hmmmmm........that might be what i do, but i would really like to look into just making a copy of the BMR stuff........something without a swivle end.
Thanks for the link though, i might end up doing that instead
F'n1996Z28SS
08-23-2023 11:19 PM
