Any Tips/Advice before Changing Rack and Pinion??
i am going to be replacing my Rack and Pinion complete unit with inner tie rods on my 94 z28. Any troubles people run into i should be aware of? it doesnt seem that hard.
Re: Any Tips/Advice before Changing Rack and Pinion??
Straight forward. Measure the placement of the outer tie rods to the original rack carefully to set your new rack correctly to get your toe in alignment as close as you can to drive the car to an alignment shop. You're also ging to need a 18mm line wrench to remove the hose from the rack.
