A arms
Weight Savings- 8 lbs
Weight Savings with Chrome Moly A-Arms- 10 lbs
http://www.umiperformance.com/230010?category_id=121
![Smilie](https://www.camaroz28.com/forums/images/smilies/smile.gif)
Oooo UMI! I have a UMI panhard.
is that per side savings or total?
20lbs off the front would be great. add that with a fiberglass hood and you've dropped 40lbs
You can also save 5 -8 lbs per side by going to adj. coilovers with 2.5" x 8" - 12" springs, you save all your weight with the springs.
Or you can just drain your windshield washer resevoir , cost 0$ LOL!
The A-Arms are 8lbs a set, I know most coil over kits are 10lbs like the QA1 kit. UMI has some nice kits out with these items now
http://www.umiperformance.com/produc...ategory_id=137
autoxr166
09-25-2015 04:21 PM
