Bad wheel bearing?
Bad wheel bearing?
My front right tire is worn very badly on the outside part, and I get a whirring sound anytime the car is going towards the right side when going 40+
Appreciate the help guys
Re: Bad wheel bearing?
I'm also getting a new one because either the bearing or the speed sensor in there makes ticking noise at speeds of 30+ and it f'ing annoying. I am 100% sure its not the brakes, clutch, exhaust, or engine. I've tested everything!
Originally Posted by n2ceptor
Your hub assembly is prob bad.... Change out both, so you dont have to do the other side later on.... Cost around 70-80 dollars each....
Easy to replace... Only 4 bolts to remove...
BTW thanks a lot for your help guys, I truly do appreciate it
10-31-2016 11:09 AM
99TransAmWS6
02-12-2015 07:23 PM
