BAER track kit VS LS1 brakes
Old 08-31-2004, 10:49 AM
  #16
LT4Firehawk's Avatar
Re: BAER track kit VS LS1 brakes
You don't need to do anything with the rear. Most of the braking is done by the front brakes and the rear brakes on an LT1, LS1 or C5 are all about the same capability. All you must have are the pair of brackets for the front and the front C5 rotors. You can reuse the LS1 calipers with that setup or get the C5 calipers (along with pads) depending on how much you want to spend.
LT4Firehawk is offline
Old 08-31-2004, 01:37 PM
  #17
West South Central Moderator / Special Guest
JordonMusser's Avatar
the problem with the baer kit (which does indeed use C4 calipers) is its thin 1.10" rotor, and weak calipers.
go with the LG c5 rotor setup.
JordonMusser is offline
Old 08-31-2004, 03:53 PM
  #18
RE AND CHERYL's Avatar
Well...It looks like I'm gonna get the C5 brackets for the front, drilled and slotted rotors for front and rear along with ceramic pads from Autozone. Total bill should be around $650 and make a night and day differance in braking.
RE AND CHERYL is offline
10-31-2016 11:09 AM
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
Brake_L8
01-20-2015 09:44 AM
slocody
02-10-2003 01:04 PM
Quick Reply: BAER track kit VS LS1 brakes
