Which ball joint??
Location: brunswick ohio, small burb south of cleveland
Which ball joint??
I am finally doing the front LS1 brakes and replacing the ball joints at the same time. Can anyone tell me what price range or which brand to use for the replacements?? I have seen upper prices range from 40 to 70. Lowers range from 15 to 40. The 95 Z28 is a toy and only races street / track so I don't need heavy duty road course stuff. OEM would probably be fine. I surfed both NAPA and AUTOZONE for the price references. Moog or other, what do y'all suggest?? Thanks.
David
David
Moog ball joints and bushings would be the ticket. Here's a pic of the rear LCA bushing on the front LCA @ only 75k miles. I just bought the 1LE replacement LCAs to make the downtime less when replacing the front shocks. You may want to consider the bushings as well, since they take a beating too.
Doug
Doug
Doug
Doug
04-16-2015 09:57 AM
