Best Alignment Setting 96 Z28??
ALIGNMENT NEED HELP..SPECS
I need help on what alignment settings I should go for. I only have free time today or tomorrow to go to a shop. I don't trust what they will recommend for my setup. What specs should I go with
My car is a daily driver, weekend autocross/drag. My parts are in my sig. I would like an all around...best of everything.
thanks
thanks
Re: Best Alignment Setting 96 Z28??
From what I have looked into here is what the experts will generaly agree on...
Alignment (all in deg)
Camber Caster Toe
factory +1(± .5) +3(± .5) 0.15(± .5)
autox/street -0.5 +4.0 0.0
autox* -1.5 +4.5 1/16 inch toe out
Hope that helps.
Kris
Camber Caster Toe
Hope that helps.
Kris
Check www.frrax.com there is a sticky there.
Watch the negative camber, too much will wear the insides of the tires. I'm sure I will get an arguemnet over the maximum benefit of negative camber. I would not go over -1. Some people run -2, but their tires cord out quickly.
Castor adjustment: Have both left and right maxed out and reduce the higher to the lower. Example Left 2 degrees max and Right 2.5 degrees max. Adjust Right to 2 degrees and leave the Left at 2. I don't think you will get 4 degrees on the factory set up.
10-31-2016 11:09 AM
Hurin
12-13-2014 07:38 PM
Brandon Wittmer
12-03-2014 09:28 PM
