Best Sway Bars F&r
#16
Re: Best Sway Bars F&r
For what it's worth, I have the hollow strano bars with adj Koni's set to full soft and 275/40-17s. The car may handle better, but rides like a dump truck. In many ways street cornering is reduced because if I ran over a dead worm in a fast sweeper, it'd upset the car so bad I'd bounce into the ditch.
Now I'm looking for something softer than my stock Z springs, and weighing them against removing the bars or struts. Fawking thing is about unbearable on city streets.
#17
There is nothing softer than the factory springs. I would suggest selling the car, because if you feel that it rides that bad, then it will not get any better I promise you that.
If you want something with a soft ride I would suggest nothing that's considered a sports car, so stay away from Camaro's, Mustangs, Corvettes, Acura RSX's, NSX's, etc.
Good luck.
#18
What year is your car ?? Maybe your springs are shot . Bald tires ??
You could always get an old ,big caddy , they ride like a couch
![Big Grin](https://www.camaroz28.com/forums/images/smilies/biggrin.gif)
#19
[QUOTE=siggs229]
You're right.... Every single SS ever made, except yours, sits less than an inch lower than a stock Z28. You got special one-off springs
Originally Posted by 5.0THIS
First off, your car doesnt sit 1 1/4 inches lower than a factory Z28. 1/2-3/4 inch maybe with the SLP Bilstein/Eibach combo.
And your 100% positive of this how ????
Rob
Rob
#20
#21
[QUOTE=5.0THIS]
Thanks for the info
I knew my car was rare
Rob
Thanks for the info
![ALERT](https://www.camaroz28.com/forums/images/smilies/alert.gif)
Rob
#22
![Confused](https://www.camaroz28.com/forums/images/smilies/confused.gif)
#23
I have the same set up as dan.. ST35MM solid front bar and 21mm 1LE bar. The balance is just right for me. That said, if money were no object, I would got the Strano 35mm hollow bar for the weight savings. The ST bar is stiff, but is a pig in terms of weight. It makes for a pretty good curl bar to work on your biceps hahaha.
Originally Posted by stereomandan
My opinion, 35mm hollow or solid front, and 22 hollow or 21 solid rear.
Personally, I have the 35mm solid front sway bar, and 21 mm 1LE rear bar and it's juuuust right with my stock springs and Bilstein HD shocks.
Dan
Dan
#24
Originally Posted by Bud M
A 25 rear bar is too big. You need a less stiff rear bar to get the power down. Strano's 35/22 bars, though not the best in terms of fit or finish, are about the best for performance. If you want to save a few bucks you could substitute a 21 solid bar for his hollow 22.
Ok how about this one !!! Does anybody think if I used a 25 mm sway bar in back with the rubber bushing instead of the poly , this might offset the the bigger sway bars rigidity ????? ( less stiff ) Let me know if you think that is a possibility . If not, does anyoone want to buy a brand new 25 mm sway bar ?
Rob
#27
Dan
