BEST sway bars on the market?????
Hey guys.. I will be ordering sway bars next week and..i need to know...by far which is the best sway bar out there.... http://www.stranoparts.com/index.php they have a 35mm hollow...but is it any better than the BMR 32mm solid???? I just wondering who t go with...thanks
Re: BEST sway bars on the market?????
i dk what would be considered "best" it might depend on your driving style and what your doing. a lot of people recommended the suspension techniques i think it was 35mm soild bar, which is what i got. probably the best mod ive done to the car so far
I like my Hotchkis 36mm hollow.Darn good fitment,quality hardware.Brackets have grease zerks and are gusseted. Powdercoat is flawless. I got it from tire rack.Only the front bar for $250.
BTW I had the ST35mm pig of a bar damn heavy. And I swear this 36mm is a little stiffer than it is.
I hated the BMR 32mm I can hardly even tell it from stock.
T.
T.
I don't know if www.lgmotorsports.com has the kind of sway bar your looking for but you might give them a look anyway. There known for some pretty high end autocrossing suspension pieces as well.
A solid sway bar does not have that big of a benefit over a properly designed hollow sway bar of the same size. Yes, there is a slight improvement in stiffness, but I really do not feel it is worth the weight penalty. I have had stock, 1LE and now the Strano 35mm hollow, and the best of them is the Strano 35mm bar. It makes a much more noticeable difference than going from stock to the 32mm 1LE unit. Plus for only $199, you really can't beat it. Finally, considering how nose heavy our cars are to begin with, the absolute LAST thing they need is additional weight on the front end.
[Interior] Interior protection
themex2002
09-02-2015 03:47 PM
