Best sway bars and sizes
I am looking at the spohn front and rear sway bars. The car is for a dd and occaisional track time both strip and autox. I know I want solid but not really sure what size's and what brand are the best.
Re: Best sway bars and sizes
hard to go wrong with the 32/21mm bars from BMR
it's a good all around setup...made AMAZING improvements on my cars handling...on both my 96 and now my 99
Not sure why you want solid bars, I'd get Strano's 35/22 bars, 32 is a bit small on the front and Spohn's 32/22 combo will be tailhappy. Strano's will be lighter too. I've had the BMR bars and they are not bad but the Strano front bar is better IMO.
If hollow, go with the Strano 35mm front and 22mm rear, if solid then go with the 35mm Suspension Techniques bar and 1LE 21mm rear bar.
I have the two solid bars mentioned and it made an incredible difference in handling. By far the best handling mod I've done.
Dan
Dan
Originally Posted by mook99TA
what do you mean by tail happy?
96SilverRam
11-20-2016 11:19 AM
96SilverRam
05-28-2015 02:09 AM
BLK1997Z28
05-01-2015 12:23 PM
