Best traction mods.
Re: Best traction mods.
First and foremost I think would be tires, Ide imagine that a great tire with a stock suspension would do WAY more than a crappy or even average tire with any amount of suspension mods....
Would it be better to buy a package like this one
http://www.lmperformance.com/4168/2.html
or like these
http://www.lmperformance.com/1825/2.html
http://www.lmperformance.com/1828/2.html.
Also what size drag tire and rim would you recomend.
or like these
http://www.lmperformance.com/1825/2.html and some bigger rims/tires would do the trick. First should be the tires, then the suspension parts though.
I for one am not a big fan of the BMR torque arm. I like the Spohn because it bolts to the cross member instead of the tranny. The crossmember is just a stronger point, and won't put any stress on the tranny.
1-- frame connectors (Global West)
2-- Sphon TA
3-- coil over's in front
4-- adjustable rear shocks
5-- LCA's with spherical end's of some type
6-- tire's
7-- remove front sway bar
8--remove front bumper
9--2-3* pinion angle
10-- the right air bag set at 20-25lbs with rubber pads on top and bottom (a little work)
11-remove factory rubber spacers from rear on top of springs.
12-- keep air pressure in DR's above 22PSI.
2-- Sphon TA
6-- tire's
Originally Posted by simple
LR, this is the 2nd time i've seen you recommend the GW SFC's over some others. what is your preference with those?
Javi Fierros
06-10-2015 03:35 PM
