which is the better lca
Re: which is the better lca
The tubular's are great. I've seen the Spohn tubulars help push a 3,450# 30th SS convertible to 8.60@160+ MPH, with a 1.30 60-ft time. Definitely strong enough, and less weight then the box-section arms.
Aftermarket overbuilds everything. If tubular are strong enough for 1.3 60' times, then why make boxed ones? It's just so they can get more money for something you don't really need. Unless of course your car is speedygonzales and can pull off .8 60' times
As for the original question, go with tubular ones with rod/poly ends.
Originally Posted by Camaro_Maniac63
Actually, it is probably the other way around. Aftermarket doesn't really have liability concerns since they sell their products as "off-road" parts with no guarantees implied. However OEM parts have to be very safe and last a fairly decent amount of time without problems. One great example of how under-engineered aftermarket parts can be is K-members. Some people have broken one under normal driving conditions.
But I do understand that some aftermarket parts break easily.
carguyshu
01-22-2017 11:19 AM
96SilverRam
11-20-2016 11:19 AM
Henson071
12-30-2015 09:55 PM
