Bilstein HD Shock question
#16
Re: Bilstein HD Shock question
Originally Posted by 94Z28/SSw
All I was saying was, SLP put on the eibach prokit with bilstein hd's, so it must not be too bad of a setup
And SLP shocks are NOT HD's either (at least the front valvings aren't, the rears are). They have rebound added and compression taken away when compared to the HD's.
So the entire statement above is.... incorrect.
#20
It's not really my issue if they are giving out incorrect information. I'm an SLP dealer as well at the other things I carry. I know what the parts are, including having valving information and spring rates on their shocks and springs. I also have that information for HD's and Pro-kits, and they don't match either.
All you have to do it check the specs on the springs.. SLP springs lower the car about 3/4". LT1 Pro-kits are about 1.25" lower, and LS1 Pro-kits are speced @ 1.5", but are sometimes as much as 1.75" lower. The springs are Eibachs, but are made to SLP's specs. They are not rebadged pro-kits. The shocks are Bilsteins, but the fronts have a different valving than HD's with about 10% less compression and about 20% more rebound. The "SLP" rear Bilstein's are in fact untouched HD's. They are the only one of the three items (front shocks, rear shocks, set of springs) that are off the shelf and available from other places.
You can choose to not believe me, but that is the case. And if you know much about me, I'm not big on making assumptions.
#21
Thats fines, I understand what your saying, but I was simply telling you what SLP was telling me. Because when I was deciding what setup to run, I was told what I stated earlier. Thats all I know. Sounds like you know your stuff so I believe you.
#22
ZBLKHELLRZR
08-18-2002 07:57 AM
