bilstein HDs with stock Z28 springs?
Our cars have SHOCKS not STRUTS. You might get flamed if you continue to call them struts. But if the LT1 HD shocks you are purchasing are interchangeable with LS1 f-bodies, then yes, you can install them. Higher quality shocks = better ride. In our case, any replacement shocks = better than DeCarbon's. You aren't lowering so installing more expensive shocks will only make your car ride better.
Don't forget an alignment after it's all said and done.
Good luck!
Good luck!
F'n1996Z28SS
08-23-2023 11:19 PM
CamaroHeed
03-18-2020 09:50 PM
