BMR Fabrication Torque Arm
Re: BMR Fabrication Torque Arm
i'm getting a rattle when i drive my car and the rattle increases in frequency with speed,
it is not engine or transmission related
looks like an issue around the rear u-joint
but i didnt spin the driveshaft yet
When you lower your car you will probably have clearance issues with the torque arm and the tunnel and possibly with the parking brake cable bracket. I did when I installed an adjustable BMR torque arm.
I cut out a section of the tunnel and welded a piece in to give the torque arm more room. I also moved the parking brake cable bracket to one side about 3/4". No more clearance issues.
i didnt take a good look for any other possible clearance issues
i didnt have any problems putting the torque arm in, at least not with the e-brake cables or brackets
its a pretty loud rattle for what its worth
This is a little off topic but I have a Universal trak pak or whatever its called. It was on the car when i bought it. It has clearance issues with the tunnel. Whenever I shift hard or anything like it, it bangs against the tunnel. I think the past owner installed it too high when he welded it in with the bar that goes across. Looks like I am probably going to have to cut the weld and redo it. Also, it still has the stock driveshaft.
I got the BMR TQ arm w/ the stock driveshaft. Set the pinion angle to -2. I have no clearance issues. THe only clearance issues I have are the Y-pipe for the LT's. But that's a different story.
stock irocz springs, stock ride height
stock rusty old drive shaft,
i'm going to swap the rear for a 89 formula disc brake rear i hope when i bolt the torque arm and the drive shaft to this rear end i'll cure the problem
