BMR Torque arm relocation bracket
I have a BMR torque arm and relocation bracket. How do you know what hole setting to use on the relocation bracket. Do you adjust it according to pinion angle?
I believe this is what he's talking about.
I know the top holes are for stock location, other then that contact BMR.
http://www.bmrfabrication.com/misc/TCC006.jpg
Yes thats it. Its not a track pack. I used the second hole from the top and set the pinion angle at -2 degrees. I had no choice but to use the upper holes because of y-pipe interference. Is there any advantage of one position over the other? If need be I could modify the y-pipe.
Re: BMR Torque arm relocation bracket
Generally, you'll feel more vibration, and hear a bit more noise. A lot of it depends on the bushing used at the front of the torque arm. A poly bushing will be a bit noiser than a rubber bushing. An aftermarket TA with a spherical rod end will be a lot noiser.
I have the Spohn TA with the spherical rod end, and the noise is not objectional. But then the car is pretty noisy to begin with.....
I didnt notice much difference in noise but my car has a open cutout, I did notice more vibration, i find it annoying. I put 1/8th inch rubber in between the relocation bracket and the body, helped alot but i get a slight vibration, between 52 and 58, basically crusing speed lol. Next stop for me is to find someone who can dynotune odb II or convert to odb I somewhere in Michigan. I put 370 RWHP thru a dana 60 and M6 with a mail order. I HOPE THERE IS MORE IN IT lol.
carguyshu
01-22-2017 11:19 AM
