BMR Xtreme Shock Tower Brace
Is it really worth the money to get the stronger Xtreme duty STB that BMR offers or should I just stick with the normal one. I believe there is also another one in between. Which one should I get??
I think the extreme STB is too extreme. I would just get the chromoly if you really wanted one. But before I did a STB, I would do subframe connectors, or if you really wanted to feel the corners, get a new Sway bar.
I did my STB before I had subframe connectors and I could tell the steering seemed more tight and it cornered better. I bought the SLP. Kind of a PITA to put it on. I had to compress the spring on one side to get it to bolt up.
If you want better steering control, forget the STB and buy a 35mm front sway bar.
Much better control, more crisp steering, less body roll. They are about $150.
Suspension Techniques makes them, and www.stranoparts.com sells them.
Dan
Dan
Bigfatrat
Parts Wanted
10-16-2015 04:48 PM
