Bouncy Rear Suspension
Howdy:
My suspension in my 2001 SS is too loose and bouncy in the rear and I need suggestions.
My suspension setup includes:
Eibach Springs and Bilstein shocks. http://www.slponline.com/view_product.asp?P=70002
Reinforced Panhard Bar:
http://www.slponline.com/view_product.asp?P=96701
Heavy Duty LCA's
http://www.slponline.com/view_product.asp?P=96702
21mm Rear Anti Sway BAr:
http://www.slponline.com/view_product.asp?P=70003
SubFrame Connectors:
http://www.slponline.com/view_product.asp?P=70801
Strut Tower Brace:
http://www.slponline.com/view_product.asp?P=70005
Tires: BFG G-Force KDW's
http://www.slponline.com/view_product.asp?P=81000A
What can be done to tighten up the rear suspension and get rid of the bounciness?
Heavy Duty LCA's
Strut Tower Brace:
Re: Bouncy Rear Suspension
if the eibachs are variable rate, that's probably it. go with linear eibachs (125# or 150#) and weight jackers (ride height adj) from strano. he could revalve your bilsteins too, that should eliminate the bouncy-bouncy feeling.
Is your car lowered? Do you have LCA relocating brackets? When you lower your car, you change the angle of the LCA's, and will cause wheel hop & "bouncy rear suspension". The proper solution is relocating brackets, which will correct the angle by lowering the mounting point of the LCA's. The ideal angle would be parallel to the ground, or for some applications, even having the rear LCA mount sit lower than the front mount. Nevertheless, lowering your car w/o LCA relocating brackets will result in your front mount sitting lower than the rear mount, and you don't want that...
Some of these posts make me think the suspension geometry may be off. The back end sits a few inches lower than the front. Would an adjustable Torque arm be a good idea?
Some of the problems are the suspensiuon is overly bouncy in the rear in a straight line, there is excessive weight transfer to the rear when accelerating, and when accelerating around corners, the weight transfer is to the back rear tire on the outside of the corner, and it can be so bad as to lead to wheel spinning.
yes, koni shocks will help as the stock shocks are inadequate even for the stock springs.
35mm front sway bar will also hunker down the front and help too i think in turns. i'm running the hollow 35 from Strano and noticed a big diff. i already had konis, subframes, ground control adj fronts, and linear eibachs.
i also used to run the variable eibachs and thought they were too bouncy even w/ the konis. much better now
F'n1996Z28SS
08-23-2023 11:19 PM
94z28jbw
09-08-2002 03:22 PM
guionM
18
07-23-2002 04:24 AM
