Braided steel brake hoses, traction control?
Old 11-16-2011 | 12:43 AM
jpkalas's Avatar
Hey all..
Russell Performance sells a 5 line kit on JEGS and Summit for braided hoses for my '96 Z28. According to JEGS though, they will only work for cars that do NOT have traction control. My car does. Will these hoses work for it? I know traction control is connected to the ABS, but what will happen if I put those on. Any thoughts, ideas, or other products would be helpful.
Old 11-16-2011 | 03:18 AM
NJ-LE's Avatar
Re: Braided steel brake hoses, traction control?
jpkalas:
ISTR Russell and Earls also have 6 line kits for traction control cars. Give them a call for the correct numbers.
Old 11-16-2011 | 03:47 AM
NJ-LE's Avatar
jpkalas:
I came across the following. There don't seem to be separate TC line kits for LT1s. I believe other have used the following, hopefully they will post their solutions. (I used the LS1 5 line kit for my upgrade [no TC])
http://marylandspeed.com/russell-sta...90-p-2163.html
Russell Stainless Steel Brake Line Kit (Set of 6) - 1998-2002 Camaro & Firebird (w/ Rear Disc Brakes & Traction Control)
Part # RUS-692290
Old 11-17-2011 | 07:18 PM
jpkalas's Avatar
That part number for the LS1 brake line kit is the same part number for the LT1 brake line kit on JEGS. They should be fairly compatible correct? Because if it isn't going to mess with the ABS sensors I think I'm going to go ahead and get it.
Old 11-17-2011 | 07:21 PM
jpkalas's Avatar
Whoops, no it isn't. Sorry!
You think the 6 line kit for the LS1 would fit my '96 LT1 then? I don't see why not.
Old 11-17-2011 | 10:47 PM
hotpart's Avatar
Former Vendor
The LT1 hoses and the LS1 hoses are different in the front. These are the hoses that we build in house. These are the ONLY OEM fit and finish hoses on the market that are DOT legal made from Teflon lined stainless steel.
http://www.hotpart.com/shop/index.ph...ct_detail&p=39
Old 11-18-2011 | 02:54 PM
jpkalas's Avatar
Ooooo....so that kit will fit my LT1 that has traction control? Message me with a price if you could sir. I'd appreciate it.
Old 11-18-2011 | 07:59 PM
hotpart's Avatar
Former Vendor
They are $170.43 for the complete set with free shipping to anywhere in North America if you use Coupon Code "Free Shipping" during checkout.
Old 11-19-2011 | 10:55 PM
jpkalas's Avatar
I sincerely appreciate it good man. Thank you!
dluna333
Parts Wanted
03-06-2015 07:11 AM
Jlo
02-03-2015 09:41 PM
squarehead
01-15-2015 07:02 PM
ddr698
01-09-2015 10:05 AM
07-04-2005 05:00 PM
Quick Reply: Braided steel brake hoses, traction control?
