brake fluid flush--cant get 1 caliper bled
today i flushed the brake fluid in my 94z (fluid looke like used oil). everything went good till the front passenger caliper. it stoped sucking fluid, i used mityvac. well while it had vacuum and with the bleed screw loose i pumped the brakes thinking it had some trash in there blocking it and i could push it through. came back around and there was no vacuum and i assume it sucked alot of air in the system. now i cant pull fluid through it only air. i been pumping the mityvac for like an hour trying to get fluid and i only get a little bit with mostly air. anyway i can fix this faster or do i need to just keep pumping. i figured after an hour it wasnt going to work.
what can i do?
what can i do?
cause its the inner linner that collapses right?
carguyshu
01-22-2017 11:19 AM
CGM2010CAMARO
04-07-2015 07:44 PM
Death's.Stalker
02-26-2002 12:53 PM
