Brake light is on....can anyone tell me why?
Old 07-22-2004, 02:08 PM
v7guy's Avatar
the E brake still works, everything seems good there, the fluid is full, so why does the Brake light stay on all the time? The ABS light is off and the car seems to not stop real fast, but nothing that seems that bad really, I need suggestions on things I can check, and how I can check them, all advice in greatly appreciated
v7guy is offline
Old 07-23-2004, 03:06 PM
JG94Z's Avatar
Re: Brake light is on....can anyone tell me why?
check the brake switch with an ohm meter located in your console, it may be damaged from use.
JG94Z is offline
Old 07-23-2004, 04:31 PM
Mtrhds94Z's Avatar
'Brake' light in the DASH?
1]Check the 3rd brake light bulb... if that's out, it stays lit..
2]It's an 'E brake on' indicator..
3]It also indicates problem in one brake section['disproportionate pressure'..front/rear]
Have you 'opened' the brake system lately?If so it takes like a 400psi application to clear that..
If not, look for a leak..
Mtrhds94Z is offline
dluna333
15
03-13-2015 12:30 PM
squarehead
01-15-2015 07:02 PM
AlaskaZ28
01-01-2015 12:30 PM
Red97LT1
9
12-17-2014 06:13 PM
Quick Reply: Brake light is on....can anyone tell me why?
