brake light wont go off
Well i HAD just installed ls1 brakes up front, then after everything was on, found out my left spindle was bent or something. So i had to put my lt1 brakes back on, got them bled and all is good. But i cant get the brake light to go away in the car, any suggestions?
Could be from the pressure differential switch by the master cylinder. Now that all your work is done, it might be ok. Try pressing on your brake pedal real hard. If you hear a click, the light should go out.
The "BRAKE" light indicates two different things.... 1) The e-brake is on, or the switch is stuck "on". or 2) there is a significant difference in line pressure between the front and rear braking circuits, or the switch in the block on the side of the ABS motor assembly is stuck.
Shoebox told you the typical way to "unstick" the pressure differential switch. Apply an extremely high pedal pressure. If that doesn't solve the problem, then the light may actually be telling you there is a problem with the brakes, and you need to find out what it is. Did you bleed the ABS unit first?
dluna333
15
03-13-2015 12:30 PM
squarehead
01-15-2015 07:02 PM
