Brake Line Issues
Brake Line Issues
Been fighting brake line leaks since installing an SJM ABS Delete kit. Leaks from the bottom of the solenoid and from the fittings going into the front manifold that replaces the ABS unit. Any tips on stopping brake line fittings from leaking?
Re: Brake Line Issues
Flares going into the ABS Delete manifold appear to be bubble flares, the other ends - to the "stock" brake system are standard double flares, and don't leak. Could I tell by looking at the ABS Delete Manifold whether or not it was designed to accept bubble fittings.
10-31-2016 11:09 AM
dluna333
15
03-13-2015 12:30 PM
kclarson
08-22-2002 04:04 PM
