Brake Roll Control
Brake Roll Control
Hey Guys...
Just a few questions for those that have the Roll control, whether its hurst or slp or whatever...
1. Is it worth it?
2. Easy to install?
3. How often to you use it?
4. Any preferences of brand?
5. And Have you had any problems with it?
Thanks alot and hope you can help!!
James
1. Is it worth it?
2. Easy to install?
James
You can get a kit with prebent brake lines. This adds to the price, but well worth it. You only use when you want to do a burn out. It's not an emergency brake or anything. Note, If you accidentally flip the switch while you are driving, you won't have front brakes till you flip the switch back.
Dave
Originally posted by LPEdave
It's actually the reverse of that. You'd have perfectly good brakes, they just wouldn't release if you let off the brake pedal. All the same, probably not a switch you want to accidentally flip, especially if you're cruising down the freeway...
Dave
Dave
I was talking about if you were cruising down the freeway.
Dave
carguyshu
01-22-2017 11:19 AM
dluna333
15
03-13-2015 12:30 PM
