Brake Upgrade
Old 12-26-2007, 04:36 PM
  #16
Black 97 SS's Avatar
o ya the website also stated that all 17" wheels that came stock on the f-body will fit
Black 97 SS is offline
Old 12-26-2007, 04:48 PM
  #17
Greed4Speed's Avatar
Strait off the Kore3 website:
The C6 Z51 calipers are interchangeable with the C5 calipers and are approximately 25% more rigid due to additional material across the bridge of the calipers. Both C5 and C6 calipers have twin Ø40.5mm pistons and utilize a pad abutment design, where the braking torque is transmitted directly from the pads into the pad abutment brackets and the spindles they mount to, leading to better performance you can feel at the pedal.
The C6 Z06 front calipers are of a 6-piston, monobloc design with a patented pad-per-piston design such that each piston has it's own dedicated pad. This feature reduces the development of tapered pad wear commonly experienced by longer pads in similar applications. Due in part to the unique pad design, the calipers utilize cast-in bridge sections for maximum rigidity and overall stiffness resulting in improved pedal feel and pad wear.
Greed4Speed is offline
F'n1996Z28SS
08-23-2023 11:19 PM
QuickSilver02
04-07-2015 11:12 AM
Jazsun
12-29-2014 12:14 PM
Quick Reply: Brake Upgrade
